Guest viewing is limited
Soil stack repair
View the thread, titled "Soil stack repair" which is posted in Boiler Advice Forum on UK Plumbers Forums.
F
Farshster
Morning, my cast iron soil stack has corroded at the top, I have removed the damaged offset piece so I can attach a new plastic piece. I need to attach a new bracket to the wall but the brackets sold from Wickes etc leave a large gap from the pipe to the wall. Are there any specific fixings you can buy to get around this problem? if I use a normal masonry screw a large part of it will be visibly exposed. In addition to this a few of the original bolts that secure the cast iron socket brackets have corroded at the wall end. Is there a quick fix to re-secure these e.g. a masonry anchor bolt although again without the use of a wood plug the bolt would be exposed. I don't really want to replace the whole stack as the rest of the pipe is in good condition.
I use 3/4 tap washers:
1. They're black
2. They don't wiggle around on the screw.
3. They're EXACTLY the right size for the bracket so don't look odd.
Reply to the thread, titled "Soil stack repair" which is posted in Boiler Advice Forum on Plumbers Forums.
Farshster,
TBServices,
