C
Clandyuk
Hi, Newbie desperate for some advice 😕
I'm trying to fit a Bath waste into the soil stack.
Bought a normal strap connector and opened up the panel around the stack, only to find that the soil pipe is in a corner and hard against two walls.
Did some Internet browsing and found a MultiKwik Easy Boss connector in Wickes that seemed would fit the bill - blurb says no straps/glue etc and can be placed
easily. Ha, not in my stack!
Having cut the hole (57mm) I now find that the boss won't "fix" into the stack.
Maybe its too thick (just under 10mm) or the fact that its an old black hessian and pitch pipe (1960's house).
Have just spent the entire evening trying to get it to seat properly, but no go.
I can get cable ties around the pipe, but can't find a fitting that incorporates them into the boss design - does such a beast exist?
I'm now thinking about cutting a normal strap boss and glueing it with cable ties.
Is this a viable option? Would Gripfix or somesuch be suitable?
Any suggestions would be appreciated.
Andy
Well, having had a good night's sleep on the problem I decided that I was placing too much emphasis on fitting it "as intended" and not enough on getting the job done!
Have now just fitted it using the tie wraps and sealant which, if I'd have thought about it a bit more yesterday, performs the same function (holding it immovable against the hole).
Fingers crossed and onwards to more problems to be solved!!
Andy
Andy
Andy
