Guest viewing limit reached
soil trouble
View the thread, titled "soil trouble" which is posted in Boiler Advice Forum on UK Plumbers Forums.
J
jase158
Hi all, I need 2 things
1. toilet to clay soil fitting (I think the internal bore of soil is 85mm, usual fittings dont work)
2. steel to Plastic soil, it is 95mm external bore
cheers in advance
It is usually on them the sizes they will accommodate. A builders merchants is your best bet for finding different sized ones. Travis perkins, keylines or buildbase etc.
not sure, didnt get a pic.
i think they are both cast iron, didnt really take much notice.
but there was a kwikfit in the fitting already, this fitted nicely for the toilet, but need another one as customer was adiment they wanted new fittings.
I get them from Ashworths, Drain Center or PDM if you have any of them near you. Any other merchant will get them next day.
cheers all, got a 100mm x 100mm jubilee clip fitting
and a cast iron multikwik from local plumbers merchant.
turns out it was all cast iron, not clay.
cheers everyone
Reply to the thread, titled "soil trouble" which is posted in Boiler Advice Forum on Plumbers Forums.
jase158,
jase158,
