G
Guest123
Last 3 jobs, I've used cheaper solder ring fittings from Screw Fix instead of usual Yorkshire and on all 3 jobs, solder is getting into the pipework and causing blockages at taps and showers. It appears to me that these fittings may have too much solder and the excess is running inside the fitting. Pulled out a complete ring of solder from a compression elbow connected to a shower. Never had this problem before and I always flush out pipework of flux and debris from the water supply but never rings of solder! The finished joints are however fine with a nice ring of external solder.
