Guest viewing is limited
Soldering for a DIY'er
View the thread, titled "Soldering for a DIY'er" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
A
asadm
Hi All,
I am planning on laying out two zones of Flow and Returns in my property in preparation for a plumber who will install my unvented cylinder and a system boiler.
I anticipate requiring around 80-100 metres of 22mm which will need to be soldered in places. I may also require the 15mm copper tube falling down to the rads but I may do that in plastic as I want it to appear behind the rads and then connect on to the valves from behind, like they do in new builds. I am being advised to achieve this type of connection with 15mm plastic pipe which will drop down from the 22mm copper and then give me enough flex to bend and connect to the valves.
Returning to the original question - what do you advise me to purchase by way of blow torch? As I said, this is a one-off project and the prices of torches vary from £10 to £150.
Well with the greatest respect you've just turned your nose up at the torch we've all recommended. It's all about the control of the heat as well as the ferocity of the flame. A diy torch will just cook the joints before you've had a chance to get solder in them. With the best will in the world it may not even be a joint that is poorly soldered and shows a leak now. It might be one that inexplicably blows off under full pressure dispensing mains water through your property in 2 months time. This is why we're all a bit concerned for the plumber as we know which way the finger points when leaks happen
Thanks Riley. Once again, I appreciate all the advice you are providing. I will go with the consensus on this. Your explanation has been useful
Isn't software a very different beast though?
Where's the DIY spirit if I pay for every piece of work? I will pay for the boiler and Cylinder installation but piping doesn't feel like its beyond the wit of a DIY'er. Do you seriously feel that a DIY'er shouldn't be touching a set of flow and return pipes?
its not that I feel you shouldn't be touching them I just can't get over the fact that a plumber is happy with this set up, I would never work in the situation you are creating. To me your a proffesional within your field and we are proffesional in ours, it just rings alarm bells that your plumber is happy with this set up.
There's DIY, and there's DIY.
If you were planning to change a set of bath taps it'd be a different story. The layout of your pipework can affect the efficiency of your system and cost you a lot of money over the years. Bad notching of joists could cost you a lot more than that, not to mention the daily annoyance of noisy pipes.
Your spirit is admirable but it's like me building a drag-and-drop website on one of those sites that lets you create your site for £1. It will never look as good or rank as well as one created by a pro.
Joints can sometimes look fine, and hold pressure for weeks or months before letting go. This sort of job, with pressurised pipework concealed under floors, is not one for someone who's never soldered.
Much as I detest plastic, if you are determined to do this, I would very strongly recommend you use poly pipe, as you can run huge lengths with no joints.
If you are going ahead with doing some of the piping and soldering yourself, then do loads of practice soldering first. Don't practice on the real thing.
When I did my first soldered joint, it was watched over by a professional and I only got to start after I had watched perhaps thousands of joints in detail being prepared, assembled and soldered carefully.
I still have to use all the tricks of the trade I learnt to solder any solder joint in any situation - awkward or not. It's been a few decades of doing it and I still have to be careful. That why I fear a diyer soldering, as their skill is probably nil.
Thanks Best. Now I'm worried!
I wont have the privilege to watch a thousand joints but I've certainly seen tens of them on you tube. I will definitely run some practice joints first
With respect, thats roughly akin to watching lots of p o r n and thinking it will make you a good lover.
I get the impression from your comments that you feel that software development is a very skilled job requiring highly skilled intelligent people and that plumbing is just joining pipes and anyone can do it. I am a gas safe heating engineer, plumber and Electrician, I also have a computer science degree and worked as a software developer for several years I know which industry I find more challenging and certainly more rewarding.
Reply to the thread, titled "Soldering for a DIY'er" which is posted in DIY Plumbing Advice on Plumbers Forums.
asadm,
Dotty,
