Hi there
I am struggling to contain my fury and discontent to find that I have a Drain Channel outside the back of my new house which is leaking but seems to me to have been seriously bodged so need some advice from someone who may know how to fix.
I have posted a couple of pictures of the problem, the detailed one shows the drain channel which must have been angle ground out in an oblong which falls about 12 inches down into a clay drain. The problem is the connection between the clay drain and the drain channel, its plastic barrier which now leaks alot, and is non-standard. The leaching water is causing smells in the house.
What's the best option? Replace the whole meter section of the drain channel ( type unknown, no branding and try to fix ) and fit with another section and try to match it or some more creative solution that won't involve me breaking the section out of the concret?
Your opinions would be appreciated!!
Best
diy
Best
diy
