View the thread, titled "solvent weld fittings advise" which is posted in UK Plumbers Forums on UK Plumbers Forums.
sasik
Hi
I am about to replace a leaking solvent weld fitting and after cutting the old fitting off I noticed the some damage on the pipe ( happened when I cut the fitting off). I can't
shorten
the pipe any more and I would like to know, if I put plenty of solvent (glue) on the pipe and on the new fitting will that make it a water tight
joint
Thanks sasi
yer normally if the pipe is clean you will get away with it , well what have u got to loose?!
Reply to the thread, titled "solvent weld fittings advise" which is posted in UK Plumbers Forums on Plumbers Forums.
