Speedfit pipe - direct connection to top of cylinder?
View the thread, titled "Speedfit pipe - direct connection to top of cylinder?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
DIYPaul
Hi again, another novice question...
I have a vented hot water cylinder. I need to replace the connection out the top of the cylinder.
I've read elsewhere that you should only use copper for the first couple of foot closest to the cylinder, in case of overheating (i.e. it would be too hot for plastic pipe). But I've read through JG's documentation, and it says you can actually make a direct connection using their pipe.
What are your opinions on this? I'm tempted to play it safe and use copper.
If JG the fitting manufacturer state you can, then take it as read. Personaly I would'nt for the first metre. But I don't use the stuff (old school copper and solder fittings clipped horizontal/verticle pipes in parallel with one another).
Shand Group products PVC pipes, Plastic Pipe, pipes & fittings, PVC pipes & fittings, Column pipes, CPVC Pipes & Fittings manufacturers, Exporters, Suppliers in bangalore India. Shand Group conform to highest levels in quality and are tested for strength and durability under the most stringent international standards
Visit more: PVC pipes, PVC pipes fittings, pvc fittings, PVC pipes suppliers, PVC pipes manufacturer, PVC pipes & fittings Manufacturer, Suppliers, Exporters in Bangalore, India.
Reply to the thread, titled "Speedfit pipe - direct connection to top of cylinder?" which is posted in UK Plumbers Forums on Plumbers Forums.
DIYPaul,
Shandgroup,
