R
Ray Stafford
Dear All
It would appear that our Intergas boilers are now in stock.
Available [DLMURL="http://www.tradeonlyplumbing.co.uk/heating-hot-water/boilers/gas-boilers/gas-combination-boilers.html"]here
[/DLMURL]
and in all our branches over the next few days.
There are 3 ranges. All have the innovative heat-exchanger with the wide waterways, and only 4 moving parts. All will produce hot water, even when the pump has failed.
The Eco RF and HRE ranges come with separate expansion options. The more budget conscious [DLMURL="http://www.tradeonlyplumbing.co.uk/heating-hot-water/boilers/gas-boilers/gas-combination-boilers/intergas-rapid-combi-30kw.html"]Rapid[/DLMURL] comes with built in expansion, but its usefully mounted at the front of the boiler, on a hinged bracket. Brilliant idea, and I suspect every UK manufacturer will be copying it soon. It has a 3 year warranty, and is the closest visually to a "normal" UK boiler.
The [DLMURL="http://www.tradeonlyplumbing.co.uk/heating-hot-water/boilers/gas-boilers/gas-combination-boilers/intergas-eco-combi-rf-30kw.html"]Eco RF[/DLMURL] range has a 10 year warranty*, and, as the name suggests, comes with a free Honeywell RF programmable stat. You won't be surprised to learn that it is not the cheapest in the range, but once you account for an RF stat worth £100, and the 10 year warranty, it may be the best value.
The [DLMURL="http://www.tradeonlyplumbing.co.uk/heating-hot-water/boilers/gas-boilers/gas-combination-boilers/intergas-hre-combi-24-18kw.html"]HRE model[/DLMURL] is probably the only model that UK installers will have come across, and used to have a 5 yr warranty, now moved up to 7 years*.
There are lots of cheap and nasty, or "me too" boilers on the market, but Intergas represents an actual choice for the installer - one that we think will appeal to a significant subsection of the market.
Thanks for reading
Ray
*subject to attendance on an Intergas training course
[/DLMURL]
Thanks for reading
Ray
