Evenong chaps boiler replacemant job ive gotta do customer has requested a stainless hex any recommendations, heat only around 15 kw, eco blue vallient or viessman , Cheers team
What they like to install Shaun , never fitted one before was looking at the eco blus as easier cos i would need the extra cable
very easy to fit (left flow right return as you look at boiler)
10 years if your viessman approved (or i think if you pay round about 200 they will up grade it for you dont know if thats still running)
Shaun , unless somthings changed the aditional warrenty is only available on the combis , not the open vent 100's, I stand to be corrected lol
Destroyer , they are just about bomb proof mate, open vent I wouldnt fit anything else . They come with a lead to conect to the pump to to the boiler to provide a pump overrun , but viessmann are happy if you dont use it .
thought it was all models (of the 100-w range)
Will report back !!
So the pumps wired from the plug they supply direct to pump then it just needs permanent l n e ?. And the most important question do they fit in a kitchen cupboard
Started it today instead of Thursday nice little boiler to install need to wire it up tomorrow , thanks for the advice lads
Ive got an open vent job coming up I would normally fit Ideal but might give veismann a go if there that good thanks
everything went ok? and any pics?
Yeah not to bad, take it the 90 just sits on the top and isn't screwed found instructions a bit vague, I'll try and take some pics they come out a bit blurry though smashed camera lens
for some strange reason viessmann say dont put screws into the flue, but i always put a couple in one either side, the warranty is £120 for 10 years if you are viessmann trained, (one day course)
Reply to the thread, titled "Stainless hex boilers" which is posted in Boiler Advice Forum on Plumbers Forums.
