Can you get work on new housing estates just to get started ? Ok perhaps only doing simple stuff to start with, and you will need the right site safety quals. Do you want to get more qualifications at same time as first job in order to move on e.g. to pressurised stuff, and gas ?I'm in the same boat. I'm 36! I done a level 2 plumbing, but no one takes you on with little experience. I'm good on the tools, what's stopped me is there's a lot I don't know. I would like to learn, anyone here want to give me a chance on the field.
William.
Starting with a clean sheet always seems attractive in a 'grass looks greener over that side of the fence' sort of way. But qualifying as an electrician / plumber is a big investment of time and money and I don't know about money but at 56 TBH you are short of time and you'll be lucky to break even on the investment.I really appropriate you advice.
Thanks for your time.Can you get work on new housing estates just to get started ? Ok perhaps only doing simple stuff to start with, and you will need the right site safety quals. Do you want to get more qualifications at same time as first job in order to move on e.g. to pressurised stuff, and gas ?
Cheers,
Hi Roy I didn't think of that, maby it's worth popping into a new build site. And asking if I could do the second fix. It's worth a try.
That would be good but I'm in Northamptonshire. I'm willing to travel about 50 miles. Thanks again.Boilerburns, where are you based? I am looking for well motivated people in Oxfordshire for our renewables side of the business.
Self emp. JFDI William. There's always more to learn. Good luck.I'm in the same boat. I'm 36! I done a level 2 plumbing, but no one takes you on with little experience. I'm good on the tools, what's stopped me is there's a lot I don't know. I would like to learn, anyone here want to give me a chance on the field.
William.
Reply to the thread, titled "Starting plumbing at age 56 ??" which is posted in UK Plumbers Forums on Electricians Forums.
