Bawheid
Go easy on me as this is my first post 🙂
anyway, I am in the process of getting my heating changed over from a combi boiler to 'old type' system with maxipod in attic, I have a good few questions tbh but I'll start with what might be a simple few questions. The boiler has a stat fitted and I also have a digital type stat in the hall. Can the system work properly using both these stats ? I mean say the boiler stat is set to 70o and the hall stat set to 21o, if the house stays around 21o, then the boiler prob won't even get the water heated up to 70o
that all makes sense in my head but when I type it out it doesn't look right lol.
another wee question regarding the timer/stat, there is a 4 core cable going from timer to boiler hut, the burner and pump output cable are connected together, I'm thinking this is wrong. Should it be wired so say if its on timer for a two hour period, power should go to the pump constant and the cable for the burner go via the stat in the hall ?
