View the thread, titled "Stonehouse" which is posted in UK Plumbers Forums on UK Plumbers Forums.
stonehouse
I have raburn royal solid fuel cooker for h.w. And c.h. The output is not enough to heat all my rads can i fit larger tank in the fire box or any sugestions other than larger model have been told i could have an l shaped tank, would mean taking out fire bricks at side and dismantling cooker to fit is this feasable
derek
Hi. The output is inadequate for the job you want it to do. You are not the first but fitting larger boiler water jacket will not make a lot of difference. If anything you will get less fuel in. The only way they work for that output, is on a windy day with the bottom off, and keep throwing the coal on. Not practical. Good Luck
Reply to the thread, titled "Stonehouse" which is posted in UK Plumbers Forums on Plumbers Forums.
