View the thread, titled "Stop Tap Advice Please" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello, So just moved in to a property and can't find the internal stop tap looked everywhere, I just wanted to check that the the pictures attached where my metre is is the external one and I cam use this to turn water off ? The key was in the hole next to metre , Thanks
Yes, that should be yours, but double check before cutting into any pipework or disconnecting anything. What type of property is it?
It's a semi, my neighbour advised its ours and his is next to it, his internal stop tap is undersink but I can see one in ours and the previous owner has a built in washer so can't pull it out without cutting the plimf, so just wanted to check I can use the external one incase of an emergency
If your neighbour’s is under their sink, then yours might be similar, can you pull the plinth/kickboard down?
Have you checked the unit to the right in the bottom half of that one should be a cut out if there a stop tap but likely it’s behind the washer
Reply to the thread, titled "Stop Tap Advice Please" which is posted in UK Plumbers Forums on Plumbers Forums.
