View the thread, titled "stopcock internal" which is posted in UK Plumbers Forums on UK Plumbers Forums.
dave1
i need to change/ repair an internal stopvalve trouble i have is very limited access and stopcock head has snapped off, i plan to try and split the valve and change the guts with a new one, if it is the same size thread which i doubt it will be, if not has anyone else got any ideas??
turn stop valve off out side property, so that the incoming water mains is dead, and just put a new one on, your only bustin your balls by changing the guts, good luck 🙂
was going to urn off outside, but like i said access is very tight and to cut out more boxing in a decorated lounge, the pipe is stainless steel aswell should be fun, anymore advise welcome
socket set with extension bar will get you down into the water toby?🙂
Reply to the thread, titled "stopcock internal" which is posted in UK Plumbers Forums on Plumbers Forums.
