View the thread, titled "stopcock no water flow" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Alright so we made a bit of a mess the other day. Pulled the washing machine out and the pipe snapped off the back of it and flooded the place. It was connected to the pipe on the right. It had a stopcock on it identical the the blue circled one, but turning it wouldn't shut the water off so it was blocked off with a new part (red circle) today. Now we have a new pipe for the washing machine but this time connected to the pipe on the left. When we turn the stopcock to get water flowing, nothing happens. Main water is on and the sink works but the pipe on the left has no water flow to it. I'm sure this is a simple fix but can't get it going.
Failed ball, or lever not engaging properly. Try removing the handle (screw in middle should undo), and try with an adjustable spanner, grips or pliers.
1. They are washing machine isolation valves, not stopcocks.
2. For the one which is not operating as Undertrained above.
3. You will probably find you have now connected it to the hot water supply. Most modern machines are cold fill only.
4. Going forward (assuming 3. above is correct):
4a. Turn off hot and cold supplies.
4b. Replace right hand valve with a good quality (e.g. Pegler) one. Just undo the nut at the top of the valve, and connect it to the new valve, discarding the equivalent nut and olive from the new valve. Note the valve may be directional with the water flow shown by an arrow.
4c. Remove left hand valve. Ideally replace "tee" above it with a straight connector. Otherwise cut the pipe about 60 mm down from the tee and fit a compression stop end.
Reply to the thread, titled "stopcock no water flow" which is posted in UK Plumbers Forums on Plumbers Forums.
