C
cooket3
Hi
I have just bought a house with a stove back boiler. After lighting it up and turning on the water pump, the radiators warm up to just above room temp and the hot water tank is the same or colder.
The copper pipes from the back boiler just get luke warm.
Should the water be pumped from the top of the back boiler or bottom?
Should the pump be pumping water away from the back boiler?
When the fire is on but the pump is off, the upstairs radiators get hotter and the hot water gets warm, but once the pump is on the radiators go cold and so does the hot water.
I have attached 2 images, hopefully these help abit. the pump pumps away from the stove and the pipe is connected to the bottom of the back boiler
