View the thread, titled "Strange greenstar 28i junior fault" which is posted in UK Plumbers Forums on UK Plumbers Forums.
zeebeedee
Customer complaining heating would only stay on for 10 mins. Boiler fired for ht/hw and worked fine. Pressure would rise to over 2 bar and the burner would knock itself off. No lockout.
Thermistors in range. Expansion vessel ok and flexi connecting it. Pump ok.
Heres the strange part , the boiler wouldn't attempt to fire for ht/hw again until the pressure dropped.
Im im convinced its overheating due to a internal blockage. Back tomorrow for a flush.
Anyone seen this before?
Can you run it with the sensors out of there pockets to test?
These don't have a water pressure switch so must be a circulation problem I would say? Not wildly over gassed is it?
What's your thinking there?
With the sensors not being able to "sense" you'll be able to see of it carries on firing. If it gets mad hot hot it'll make some horrible noises, so blockage. If it fires and runs sweet, it's the señsor/sensors.
Reply to the thread, titled "Strange greenstar 28i junior fault" which is posted in UK Plumbers Forums on Plumbers Forums.
