N
niggle45
Just had the man out to fix the boiler under warranty (only 8 mnths old) and he discovered a brown/black skin covering most of the surface of the header tank in the loft. A bit like the skin on custard in consistency (not colour), maybe about 1-2mm thick and clinging to the sides of the plastic tank. He has never seen it before & when I described it to the installer, neither had he.
The tank is covered (not quite completely) by plastic covered lagging and the water in the main tank (supplied by the same feed) is perfect.
This has obviously appeared only over the past 8 months.
Has anyone else come across anything like this? Any ideas about prevention would be gratefully received.
