G
Gunner Plumber
Iam generally new to the trade and work as a service engineer. My Question is related to Telegan Readings on Condensing Boilers in particular the worcester greenstar models as i come across them quite often. As these condensing boilers are getting on a bit 6, 7 years old and are requiring to be stripped down and heat exchanger cleaned out and can be proven by low readings at fan speeds ie usually readings they look for are around -4.2 or their abouts depending on model.If you are getting readings below this ie -1.5 or so it states to strip down and clean heat exchanger. Or in some cases your telegan ratio too high when co2 reading correct and gas rate correct. Has Any1 had much experience in this field and had to strip down a greenstar? Change seal etc. Is it Quite Simple and any hints and tips when doing so? Whats envolved? or how long it takes? Would appreciate any comments.
Cheers
Cheers
