Hi, I'm new to the forum and new to oil boilers. I have an older Worcester Heatslave 18/25 (13 years). I've been in this house for about a month. I had an engineer do an inspection before moving in and he said everything was perfect. Since then I've turned on central heating and water heating a good number of times. All seemed to be working okay, until today.
This morning I had the oil tank topped up (from 30% to 100%). The boiler was turned off during this time. After 30 minutes or so I started to smell fumes in the house. I opened the windows to air it out and after another 30 minutes I tried turning the central heating on. It didn't do anything. I waited for a while but nothing, and the smell got stronger. I then tried to turn the water heating on, and that worked right away.
I ended up calling an engineer to take a look at the boiler but they could not find a fault in it, even though I told him water heating and central heating could be turned on independently and this was not working. He managed to brute force turn on central heating by turning on both water and central, and clanking the heating intensity button up. Thermostat was set to 20C and it was marking 17C so heating should turn on. He said I needed a plumber, not an oil engineer.
An hour later I'm still getting very strong smells whenever I try to turn central heating on, and have to air out the house, which defeats the purpose.
I'm located in Aldington (TN25) and wondering if anyone would have any idea of what could have happened. And would you recommend a professional I can call in the area?
Thank you in advance
