I
IanW
We need to replace taps on the sink in the bathroom.
So we thought we would turn the water off....
However we cannot! 🙁
I can get the hot water tap off.
But when I turn the mains stopcock it turns a fair way, but the cold tap in the kitchen (and indeed the outside tap) will not stop, they certainly have reduced pressure, but will not stop totally.
We have even tried turning the two taps in the loft and the two by the hot water cylinder, but still the taps both upstairs and downstairs run.
I guess we left it for a good 30-40 minutes, so assume we would have drained any tank.
The other thing is the noise increases dramatically in the pipe leading up from the main stopcock, which feeds the kitchen sink and then vanishes upstairs.
Any suggestions.
A bit loath to call a plumber out as we simply cannot afford it, but at the same time the hot tap on the sink has stopped running completely, so needs to be replaced.
Thanks in advance.
Any suggestions.
Thanks in advance.
