Doing landlords i frequently come across flues with large gaps around them where they pass through walls that have never been filled in,
sometimes theres those rubber collars hidding the hole, but often you can look along the flue to daylight
(occasionally on bigger holes i see newspaper stuffed in by the tenant to stop draughts)
I dont why hole are so common, maybe some engineers meant to return to make good others are just plain lazy. needless to say its not really exceptable
to make good, with a small gap i've seen engineers use silicon to seal the hole and on larger gaps expanding foam
logically both would work, both can be purchased with heat resistant qualities, both are hard wearing and should last, and both should stop any air flow or transfer of unwanted gases
however in my gas book it says flues should be sealed with sand and cement, with no mention of any other suitable products.
Is foam and silicon a no no
