Cheapest possible with a warranty recommends
If you need a cheap system boiler of more than about 15kw, the lowest cost solution is usually to use a combi, take the DHW from the combi to the kitchen sink only, and use an S plan on the heating circuit to drive an unvented cylinder.
Although many system boilers are just combis with some bit removed, economies of scale and market realities often make a 24kw combi cheaper than an 18kw system boiler.
If you really want cheap, Heatline, Vokera and Ideal have some good deals. If you really want a long warranty, then you aren't going to get the dirt cheapest.
Reply to the thread, titled "System boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
