View the thread, titled "System or gravity....." which is posted in UK Plumbers Forums on UK Plumbers Forums.
Bunker
Im planning an (oil) install on a large house, heating calc suggests 40Kw. Currently in there is a 20/25 outputting on 22mm only (used to be an old cottage but extended 15 years ago). Ill run 28mm out of the boiler as far as poss.
Question is, do I keep the gravity or cap it off and go sealed - Im nervous about pressurising an old system. I cant see the point of pressure testing as any damage is often found after time rather than straight away.
Also the f&e tank shows tide marks which do not reach the overflow which suggests that the system design must be ok?
Im mainly an oil boiler guy rather than a system designer so would value your experience here...
Tanks velly much.
You mean open vented Bunker?
If its worked well open vented then keep it the same. I prefer to seal a system though, when I can.
I take a careful look at all the pipework I can get at to see what the joints look at. If it looks good I consider sealing the system. Any slight weeps showing as stains on pipes out of brass fittings, I fix & replace any cheap or leaking valves. You don't need to have the system operating at very high pressure - 1 bar cold fill is more than enough for a 2 storey house. If plastic fittings, I would worry about them.
Make sure you use a decent powered pump, or consider having split circuits with 2 lesser powered pumps if the house has very long pipe runs or/and restrictive rads or undersized existing pipes.
Deal and pressurise. It busts it burst. System will work 99.32 % better
wow that means the last mexico i sealed is now running at 170% efficency
sealing a good system will make very little difference to its eficency and can cause loads of problems with tiny leaks needing the system filling .Especially on larger systems i always leave them open if i can
Put a split plate in if its a big house and flush what you can out the open vent side.
Reply to the thread, titled "System or gravity....." which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Bunker,
Whyme,
