System overhaul.... is this good value?
View the thread, titled "System overhaul.... is this good value?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
peternib
Just a normal Joe... but would like any of you professionals to tell me if i have a fair price for below. I like to support the local man for all works and if this is fair then he gets the work.....
Bought a house last Christmas, main part around 3500 square feet, 20 year old build.
Needs an overhaul, i worked out i need the following:
New dual coil cylinder, heated from AGA and boiler
Three zone valves,
two runs of pipe from the boiler to the cylinder for hot water control only, approx 20m runs
wiring box
three zone Horstmann controller
pressure Thing.... wtf its called! you all know what i mean.
New pump, higher rating.... last one was too small.
and around three days labour to install and test.
Quoted me £1,700.... i had worked out about £1300-£1400 so i was curious to know your thoughts!
Many thanks
Peter
Hi Peter
It's difficult to comment on prices without seeing the job.
Maybe you should get a couple more quotes and see how they compare.
As said, get a couple more quotes see how close they all are. If in doubt ask to see some of their other work. You're really into piece of string territory.
How did you work out your 1300 - 1400? What % did you allow for ohp on materials?
I'd say from that limited description it sounds fair. Don't forget that installs like this aren't jobs to give to a simpleton, so if you're happy that the guy will do a good job, Go with him.
Like your attitude re: supporting your local plumber!
Sent from my iPad using Tapatalk HD
Reply to the thread, titled "System overhaul.... is this good value?" which is posted in UK Plumbers Forums on Plumbers Forums.
peternib,
TBServices,
