F
FredTheDog
Just got back from a week with some friends for xmas, turned the hot water back on and within an hour or so I had hot water gushing from the T&P valve at the same rate the tank was filling. Turned off the hot water and water supply to the tank and the T&P valve stopped after a few mins....if I turn the knob on the T&P valve more water comes out at pressure.
Read somewhere there needs to be a bubble in the tank? But I also have a cream coloured expansion vessel piped into the HW pipework spaghetti, the middle of it is about the same height as the top of the tank. No manufacturer on it and cant see a shrader valve on it to check pressure either, just a bid black plastic thing on the top.
Going to another friends for New Year so want to fix pretty quick when I get back as the only way to shower is to turn on the water supply to the tank which wastes lots of water while we shower, then turn all off and wait for it to stop draining.
Its an Ariston WRc-NSF Tank....if that helps.
Any idea what the problem could be??
FTD
FTD
