A
axil23
I currently have a 2 boiler system that does the following -
Baxi Combi - Supplies instant hot water to Kitchen sink and runs central heating downstairs which is controlled by the timer on the Baxi boiler itself.
Baxi Combi - Supplies heating to upstairs and to a hot water tank that runs of a external timer which I can set 3 times daily max to kick in to heat the water and provide heat for radiators.
Was thinking about upgrading this to a online based system that would allow me to control both boilers through my smart phone.
Which one do you guys recommend and will either of these run both my boilers off the same app?
Also would it be cheaper to run my system the way it is and time it to come on and off a through the day or through a thermostat that kicks in once the temperature drops? I live in a house that has around 14 Radiators downstairs and 14 upstairs but at anyone time only half of these are running at full blast and others are all set to frost control as they are in rooms which aren't used that often.
