Pakamish
All, I have recently installed a new bathroom sink with a mono tap. Since then, the water takes forever to drain and the sink fills up if i let the water run. I dont think i have a block as noting fell into the drain pipe when I installed the basin. I have the PVC pipes from the basin connected to the cast iron waist leading to the outside. The diameter of the waist is 32mm (could that be the problem? ) . Also the basin waist does not align to the cast iron pipe so im using muliple connects so that the basis waist can reach the cast iron pipe. Any help please!!!!! 😕
