W
Winston
What tool do you use to tighten/hold the inside of a tank conector?
i use a pair of gripsWhat tool do you use to tighten/hold the inside of a tank conector?
If you do not have the length of arms of a gorilla then use one of these. It works from outside the tank. They make them for 1/2" BSP (15mm Pipe) and 3/4" BSP (22mm Pipe) connections
Monument 83x Tank Connector Fitting Tool 22mm: Amazon.co.uk: DIY & Tools
you can go on and on buying tools for this and tools for that but generally youll find a way to manage with as little as possible especially when the jobs on the fifth floor no lift and everything has to be carried upthank you 😉
Reply to the thread, titled "Tank conectors" which is posted in UK Plumbers Forums on Plumbers Forums.
