R
rabu
Hi, can you buy the bath and basin Brass Back nuts separate? or always only with taps? also what are the washers called, the black rubber ones that go between tap and basin and basin and backnut? thanks.
Nylon washers work just as well.
Save a few brass backnuts from taps you decommission.
Reply to the thread, titled "tap back nut and washer" which is posted in UK Plumbers Forums on Plumbers Forums.
