Tap base ring leaks underneath - best way to seal it?
View the thread, titled "Tap base ring leaks underneath - best way to seal it?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I have fitted a new set of mono mixer taps to new bathroom basin pedestal and for some
reason, I’m unable to get the tap hole/base ring watertight regardless how I adjust the supplied
horseshoe tap fixing plate/washers. (tested this by pouring some water over the tap base ring
area and it leaks beneath)
What is the best way to seal the base ring of the tap?
Maybe silicon or plumbers putty?
Any suggestions?
Reply to the thread, titled "Tap base ring leaks underneath - best way to seal it?" which is posted in UK Plumbers Forums on Plumbers Forums.
Koko88,
Koko88,
