View the thread, titled "Tap pressure" which is posted in UK Plumbers Forums on UK Plumbers Forums.
davetherave
Hi all Fitted new bathroom mixer tap with shower attachment only to find I've lost most of my cold water pressure. I have a combi boiler running hot water and central heating and downstairs water seems to run off mains. Cold water upstairs runs off loft header tank. The tap instructions indicated a low pressure min drop of 1.8m from tank to tap. It would appear that I just have this height. Any suggestions for keeping these taps and improving pressure would be welcome. Thanks Dave.
Welcome to Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK!
Hi davetherave and welcome to UKPlumbersForums.co.uk!
Re: Welcome to Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumb
Thanks Dan. I'm not a plumber but like to do most things myself. I find these forums helpful as opposed to most stores where people are only interested in trying to sell you something! Cheers Dave.
Best way would be as Tom says,not matter what ,you are not going to get a good shower with the set up you have now 🙁
imho
Drain tank and join mains in loft to cold feed remove tank ..simples😎
Dave, you need to disconect and remove the tank. Connect the mains water feed pipe which supplied the ballcock onto the outled pipe from the tank, this will give you a balanced suply to your bathroom taps which will solve your problem.
Hi Brian Thanks for post. I live in a housing trust property but the landlord will only repair / replace existing old units. Do you think I can make the connection you suggest simply and still leave the tank in situ. Cheers Dave.
no reason why you would have to remove the tank but you will need to drain it as the water will go staingant so you may as well remove it at the same time
Reply to the thread, titled "Tap pressure" which is posted in UK Plumbers Forums on Plumbers Forums.
