View the thread, titled "tap stat" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
acker
Hi guys, I have CH but no HW, a friend of mine who is a plumber, but very busy, when I discribed what the HW cylinder looked like, said it was the tap stat. have you any advice on changing, draining down and re-filling the system. The boiler is a Potterton Neatheat mark 11 F 10-16.
Heeeeeeeeelp
Acker
Would have thought it was more likely to be the hot water motorised valve not working,maybe syncron motor gone in it and requires replacing
most likely not immersion heater as water is heated by ch going through the coil in the hot water storage tank, so as puddle said likely three or two way valve needs looking at.
look up acl drayton tap stat and let us know if this is what you have on your cylinder or post a couple of pictures of your cylinder🙂regards turnpin
thanks, have just looked at drayton tap stat, the one on this does'nt look the same, maybe it's old style, would like to send a pic but not very good with PC's. the one I have has two metal pins in the cap on the top. Will I have to drain the whole system down to fit it.
Acker
understand as a bit of a technophobe myself but really do need more info maybe have a word with one of your pals to help send picture. maybe someone on here can post info about sending pictures via computers?🙂regards turnpin
Thanks to all you guys for your help, tap stat fitted and running well.
Cheers guys
Acker 🙂🙂🙂🙂🙂🙂🙂
Reply to the thread, titled "tap stat" which is posted in UK Plumbers Forums on Plumbers Forums.
