Hi to all.
I want to add another radiator in the through lounge as the existing radiator is stuck under the window at one end of what is quite a long lounge. One end never gets warm so I want to add a further radiator in what is this cold spot. Behind the wall I want to put the rad on is the kitchen radiator - is it possible to tee off the 15mm flow and return on this rad and put my rad on the other side of the wall? I have a sealed combi system and all radiators are fed from above. I can't take it off the 22mm feed above as it is under a fitted wardrobe!!
