T
TiSwAs
i have a problem with a tepid radiator in our single story extension.
The central heating was fine all radiators heated nicely, since the new extension (2 years ago) the radiator never gets hot only tepid half way up the rad, I know from the build that the radiator in our unstairs en-suite was tapped into to feed the new radiator in the extension and that a rad in the kitchen was taken out and capped (both pipes had brass caps fitted and hidden behind skirting board) is this causing my problem?!?
I've tried the following -
Had the central heating off and closed all the valves - turned CH on and then opened the radiators starting from the furtherest way (now this is where i might have gone wrong) i presumed that the furtherest was the new extension radiator it came on hot the main on/off valve pipe was cold but the other side was hot and obviosuly feeding the rad (is this an issue?) then i proceeded to do what i thought was the next and so on.... it turns out that last rad to be turned on never got hot only very tepid.
The next test i peformed was to turn off the first rad (extension) and the last rad (small bedroom) whilst the heating was on - turned on the last rad (small bedroom) and it got warm-ish, then turned on the extension rad - never got hot only tepid half way up the rad
To add i was getting some wired gurgling noises from our Ensuite rad turns out that the rad was only HOT 2/3rd's way up - so i bleed it and there was obviosuly 1/3rd full of air - got that out and now that rad seems ok - i then proceeded to bleed the other rad's but they were all fine.
I bleed the tepid ones for a while too but it was only bleeding cold/tepid water out of them.
To me it seems like the system/pump doesnt have enough power to pump the water round to all rad's, I've recently had the pump (very noisy) and zone value (motor packed in) replaced (system was drained down only).i didnt tell the plumber that i was having the heating issues as i thought the replacements would solve it (maybe i should then he could have investigated it) i rang him the next day to tell him the issue he said the pump i purchased was sufficient enough for all the rads in my house.
The other tiny issue which i thought i'd mention just incase it's related is that the hot water pressure is very very poor, it's bearable in the upstiars main bathroom sink but the bath and kitchen hot water trickles out.
My boiler is a conventional system
Many thanks for your time in reading - hope someone can give me some ideas on how to resolve.
Kind Regards
Dave.
Kind Regards
Dave.
