Testing used water heaters?
View the thread, titled "Testing used water heaters?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
macka09
Hi folks
What would be the easiest way to test a string of used water heaters to make sure they are in full working order?
Mostly multipoint Heatrae Sadia 30l & 50l
Cheers guys
You mean in situ or after they've been removed?
You can test the Ohms reading through the element and the HLS and Control stats.
Test insulation the a megger.
Is that what you meant?
Yes pretty much.
Both in and out of situ would be useful for fault finding. How do you test the element and hls?
Yes pretty much.
Test Ohms reading through element. Expect around 19 for 3kw or there and there abouts. Can use multimeter for that. Also use that to check continuity through HLS (high limit stat) and control stat.
Multifunction tester for insulation resistance.
Continuity or ohms for the stat? What ohms reading would be too high/low for the element?
Cheers
Reply to the thread, titled "Testing used water heaters?" which is posted in UK Plumbers Forums on Plumbers Forums.
macka09,
Last Plumber,
