secret squirrel
The bad,
Today has been a mixed day, quoted for a new cylinder, pump and all the gumpf that goes with it, length of 22mm, pump valves (may as well as we're there) new full bore lever valves etc, this was back in July. Well, customer has sourced the pump and cylinder and wants a price to fit. Usual really, have you got all the parts, new immersion, cylinder stat (old one is a real mess, just hanging on but in bits) Oh No, thought you'd get all that. So, new price is old price less cylinder and pump. I know its not as cheap as they want. I don't know why I let it frustrate me.
However, the good. Did a set of taps for a friend, recently divorced, no money, single mum, works. I offered mates rates but she refused, I was chuffed at that but because money is always tight for her, she, like many others has a BG contract to do her heating.
She has a rad in her house that refuses to heat BG have been down twice and have been unable to get the radiator working. It is a Baxi combi boiler and the rad has a trv fitted. The boiler now heats up some of the rads when the hw is used.
:hurray:Luckily, as I was finishing BG turned up, so, I thought I'd listen and learn from the best.:20: Well, a bit of huffing and puffing the boiler was topped up and a bit more of huffing and puffing, then a run round the house and the diagnosis was, yeah, a powerflush:sick:. Usual sales pitch though. Flush not covered under the policy.
I asked, whether it was normal for the two big pipes under the boiler to get hot when the hw was being used. Oh yes came the reply:hurray:
My next comment was 'how can a sealed system need a power flush, it should have been done at the time, by the engineer who fitted it, I think you'll find that was BG and you've maintained it every year or are you saying it wasn't done properly. Surely, the big pipes the flow and return to the heating circuit shouldn't get red hot should they. They may be warm because of transference of heat but they're red hot. While your here can you explain why the pipe leading up to the trv is hot which I would think indicates a faulty TRV, I've checked the policy and they're both covered. Aren't they?'
The answer 'a power flush would help'
How would it help with a faulty divertor valve and a trv?
We'll be in touch.....😛rrr:
And the ugly, I'm back home now.......(I will be trouble for comments like this sooner or later)
