View the thread, titled ""There's a funny smell from my back boiler"" which is posted in Boiler Advice Forum on UK Plumbers Forums.
K
kirkgas
Says my wife's pal on the phone this morning, not been serviced for donkey's years, the POC's can't get through the exchanger then the flames melted the cable which put the boiler off and stopped them dying, c'mon people get your appliances serviced
get
Good god! That's a bad one. I think she got the best present this year!
Bet you were pleased to see that one Kirk standing there in your christmas jumper and new slippers :lol:
Unfortunately I've seen a lot like that.
Everything needs washed down as if you miss some soot it will be just as bad 2 weeks later.
Id just be going for a new boiler! Rather than cleaning all that up and then fixing all the other faults on system.
A well maintained back boiler is a great bit of kit that will out last most of us. They just need abit of t.l.c.
Update in this is after stripping every single bit, brush and cleaned it all then put it back together, then was chatting about checking the vent next, they mentioned they had the cellar insulated by a contractor last week, that set the alarm bells ringing, when they moved in two years ago the fitted a new carpet and removed the floor vent, obviously as they have a full size cellar under the house it was providing enough air to feed the boiler as "draughts" but getting it insulated removed the air causing the prob, I know it's not the contractors fault the punter removed the vent, however I'm going to contact them to discuss it as their actions have led to the problem as they removed the air route and if the cable didn't short out and shut the burner the people could have died
Did one of those couple of months back for a very old couple cost about 280quid for parts alone hardest bit was sourcing heat resistant cable for fire as obsolete
get
if i had a quid for every time i seen a 552 like that ............
Not a manufacturers tested part and as i am the last person on site its my responsibility and any non manufacturers part would be classed as at risk i stand to be corrected
yes you are corrected 0.75 HR would do the job,i started my career on 551/552/401 Bermudas,this cack about not type approved is just nonsense
agreed i dont remember a back boiler coming with any flex you just wired to the loose plug actually as in this case the wire burning out is one of its safety features
Plus 1 on the 0.75mm2 HR. Mfrs part upto the connector . Jesus u sure that was just two weeks and not a few months? Looks pretty heavy?
Speak to the manufafacturers and they will tell you different i agree heat resstant cable will do the job but it ain a manufacturets part
The flex was th plug in flex between the fire and the wiring socket
The cable that shorted out was the cable from the spur into the boiler so not a part of the boiler, it was 0.75 heat resistant, but as the flames were licking over it it burned through as it is "resistant" not fire proof, I sent him to B&Q to get a bit
It's hard to say when the problem started, they blocked the floor vent two years ago, it's never been looked at since they moved in so we have no idea when it was serviced, the under floor was insulated a couple of weeks ago so I think it's accelerated the problem, I got at least a carrier bag full of soot out of it, it's been a very long time since I serviced one as bad as this, but I have seen plenty this bad
Nothing wrog with that but my original post was about a manufacturers part, and i was ambushed by others
Thats your call maybe am being picky but spoke to baxi they said not been tested by them so not a genine part which is correct
Reply to the thread, titled ""There's a funny smell from my back boiler"" which is posted in Boiler Advice Forum on Plumbers Forums.
