View the thread, titled "Thermostat / Timer question" which is posted in UK Plumbers Forums on UK Plumbers Forums.
species
Hi, I currently have quite an old boiler, which has recently be serviced. It's working fine, except that the built in timer has stopped (It's a basic dial unit that just turns on and off the boiler).
I've taken a look and I can confirm that there is power getting to the unit, it just seems like the motor has finally given up the ghost.
As it stands at the moment we are controlling the heating/water by the manual on/off switch on the boiler, but what I was wondering is;
In the living room is the thermostat (which again is a simple dial temperature unit), can I replace this with an electronic one that has a timer & just leave this to control the boiler?
If so, does this just mean setting the boiler to constantly on?
Best regards & thanks
You're talking about two different things. The item on your boiler is a timer and has nothing to do with temperature. The item in your room is a thermostat and has nothing to do with time. Just change the timer on your boiler and you're sorted.
Kevin
Yes
Yes; though you may be able to bypass the internal clock.
Tell us which boiler you have (make and exact model) and we can advise.
Hi, thanks for the response;
The boiler is a Myson Apollo, but i dont know if it's 15/30, 30/50, 40 or 50/65 model, as the wiring diagram shows the one plan with all these models noted above.
Hope this helps, Thanks
Do you mean the Apollo Fanfare?
I doubt if you will be able to get a replacement timer for a boiler that old.
The easiest way to add a programmable thermostat is to disconnect the existing timer. This just means unplugging a 6 pin plug (3 x2); it will disable the clock and the two switches, but not the HI/LO switch. The six pin socket connects to a terminal block labelled L, N, HW, CH etc. You can disconnect the socket from the terminal block if you want to, but it's not necessary.
You must remove any link between HW and ON on the terminal block.
The 230v switched live output from the programmable thermostat is connected to the ON terminal of the terminal block.
Reply to the thread, titled "Thermostat / Timer question" which is posted in UK Plumbers Forums on Plumbers Forums.
