View the thread, titled "thermostat to fit to 12 year old Glow worm compact 100e is it possible?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
Jillian
Hi all,
I have a glow worm compact 100e with an On/Timer/Off controller which is about 12 years old but works fine; now I am going out to work as well I need to have a more efficient way of controlling boiler when not in.
Is there a thermostat that I or the plumber can fit to turn boiler off when desired temperture is reached instead of always using the on/off or timer setting.
Is this possible on a 12 year old boiler.
Regards Jillian
Hi jillian welcome to the forum.
Yes you can add a thermostat to your system. Get a local heating engineer to give you a quote.
Hi JTS,
Yes ,I am asking about room thermostat: on !2 year old Glow worm.
Any thoughts welcome
regards Jllian
Usually a simple job to wire in depending on distance to location of new thermostat about £15 including cable plus £50 labour, double + that if the route / location adds to the time.
That could be a reason to fit a Radio "RF" link about £70 plus the installation fee of about £50 but due to reliability and batteries that need changing, which in the long term has put many off.
Best to fit, digital thermostats wired with motorised valves for heating and Hot water, but that is moving on to another improvement.
Most electricians can also do this wiring job, to the required regulations.
Dear All
Thank you all for input and Help. appreciated.
Regards Jillian
Dear All,
thanks to all for input and helpappreciated.
Regards Jillan
I'm sorry, but this forum cannot and will not "lay upon you the secret of man's red fire"...
I'd like to point out that most heating technicians can also fit a room stat!!!!!!!
Reply to the thread, titled "thermostat to fit to 12 year old Glow worm compact 100e is it possible?" which is posted in UK Plumbers Forums on Electricians Forums.
