Looking for some advice regarding my shower. Its a thermostatic bar type supplied by a combi boiler. Recently it has started running cold after approximately 1minute. Suspected a cartridge issue. Rather than replace cartridge I replaced entire bar. I still have the same issue. It runs fine for about a minute and then goes cold. I've checked the boiler and it isn't calling for hot water. If I remove the shower head then I get constant hot water. I've replaced head and hose but have same problem. I presume I don't have enough flow to trigger the hot water demand. But not sure whats changed. All other hot water taps in house work fine.
