Thorn M44/54B questions on the system
View the thread, titled "Thorn M44/54B questions on the system" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Bigred
Hi guys, ive been asked to look at a Thorn M44/54B with a view for pricing to replace with a condensing Combi, its a bit before my time so I'm looking for advice on what to look for before I price (or go to look at it). 1. will I be able to link straight into the central heating circuit flow and return with the new unit? or will I need to remove / cap F & E and inlet etc? (I,m told there is a pump on the central heating Flow) 2. cust says that the upstairs radiators get warm when boiler on for hot water? (Ive asked if there is a cylinder thermostat fitted but apparently not) possible cause?
any advice on the type of system installed with this boiler etc. would be much appreciated (Ive looken at the scant M.I. on the discontinued models but dont want to end up with a headache by not realising what system I'm up against) Thanks
realy if you need to ask these questions you may be taking on to much
youll have to remove f&e tank vent pipes cold feed cylinder pump motorised valves cws tank reconect downservice as well as hot water
Stevetheplumber says it all, depending on age of system it will need a good power flush or replacement of radiators , check size of gas supply , water pressure and flow rate, is heating on a one or two pipe system ? check pipe size on heating system , will excisting pipe-work be-able to withstand pressurized system, pipe-work from boiler to cylinder will need altering, May be good idea to ask someone who as got more experence to give you a hand on this one !, :innocent:
Thanks Guys, as usual I have misuderstood the problem, having spoke to customer there is a lot more to the job, i.e. new bathroom, removal of the existing tanks moving and new radiators etc. which are being undertaken by a local plumbing firm and i'm not involved in any of that so i'm not holding my breath
cheers
Reply to the thread, titled "Thorn M44/54B questions on the system" which is posted in UK Plumbers Forums on Plumbers Forums.
Bigred,
Bigred,
