My sister told me that her hot water isn't really getting hot any more (heating is fine) - suddenly it's barely luke warm. I know her system is a bit of a mare, so yesterday posted a question re changing her motorised valve on bungs -
http://www.ukplumbersforums.co.uk/central-heating-forum/71739-changing-3-port-valve-bungs.html
Anyway, went to her house to investigate, expecting to find mot. valve(s) - and there are none. Looks like it's gravity hw on one set of 28mm f and R from boiler, and pumped heating on another F and R from boiler.
The system - Ideal E type boiler, conventional system, 2 tanks, gravity hw, pumped ch, modern Horstman programmer, room stat.
So, boiler fires up for ch and heats rads perfectly. There is power from the hw on terminal in programmer to the terminal block inside boiler and when hw is turned on, the boiler starts and runs fine and after a while cuts out on it's own stat, but it's only heating the bathroom rad which is also on the hw circuit. I opened a bleed valve on a rad and there is plenty of water coming out.
Looking like the boiler and programmer are fine, but have lost nearly all gravity circulation to cylinder, but still heating the bathroom rad.
Help very appreciated - I'm confused. :confused5:
