View the thread, titled "Three port mid position valve" which is posted in UK Plumbers Forums on UK Plumbers Forums.
spanner
Hi guys. To all those who have already fitted a three port mid valve ..
I've just popped over to sort out a hot water problem for a friend and discovered a sealed system with honeywell components and three port mid valve.
When heating and hot water satisfied, does it rest in A central heating or B hot water or mid???
Also are there common faults use to the mid position valve ??
The reason I ask is because the boiler only seems to fire up when cold and stays working fine until either room stat or hot water which ever first satisfied to put the boiler to rest.. After that it won't fire up for awhile until cooled down.. I've checked air pressure switch which had a tiny kink in but to my surprise its doing me head in... Any suggestions. The boiler is a Baxi solo 3 pfl..
Get those brains ticking lads..:24:
When cold the 3 port valve rests in the central heating position, i.e port A is closed and port B is open. Common problems that I've had with solo 3's are the PCB.
Any posts relating to gas, gas appliances, boilers and central heating should be posted in their relevant sections and not in the public domain.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - http://www.ukplumbersforums.co.uk/users/8668/ or Redsaw - http://www.ukplumbersforums.co.uk/users/2718/ who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competetence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Three port mid position valve" which is posted in UK Plumbers Forums on Plumbers Forums.
