View the thread, titled "tiger loop" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
jambo
hi all away to be fiting a worcester 32/50 oil fired boiler am not oftec but will be getting it commisioned by one just a bit unsure of the tiger loop cann any one assist cheers
Probably best to ask your oftec chappy. Are you sure you need one or is it that you don't know whether you need one or not?
You only need tigerloop if oil tank is lower than boiler or a long distance away
According the distance aflow and return on the boiler pump does the trick, a
Make sure the oil pump is configured for a 2 pipe setup. There should be a bypass screw come with it. Read the mi's for more info.
I've never fitted one but wouldn't hesitate or worry about doing so - as Gray says, just follow the instructions!
As it happens, I saw one today but still have no idea EXACTLY how they work - just magic!!
Reply to the thread, titled "tiger loop" which is posted in UK Plumbers Forums on Plumbers Forums.
