In a bathroom which measures 2.53 sqm with a height of 2.66 m, which 2000 mm tall Tilbrook radiator would you suggest would be required? Using a combi boiler system with central heating temperature of 60 C.
www.inspiredheating.co.uk
One window (Single glazed): 0.80 m x 1.53 m. Only one exterior wall which is cavity wall insulated. Mid terraced house.
I currently have the 206 mm wide one installed, which I thought would be adequate given the small size of the room, but I don't believe it is.
Ultraheat Tilbrook 2000mm High Radiators
Ultraheat Tilbrook offers a new design that provides a high output for a limited wall space. Tilbrook is ideal for places such as kitchens and narrow areas. Available in white.. White RAL 9010 5 year guarantee This radiator has both bottom (50mm) valve undermount connection and side connections...
