View the thread, titled "Tiny red leaver leaking under sink" which is posted in UK Plumbers Forums on UK Plumbers Forums.
O
Optiv
As the title might suggest, I know diddly squat about plumbing.
Under my kitchen sink, where the main water valve is located, there is a grey plastic pipe connected to one of the metal pipes. This pipe has a small plastic nut and leaver (red) on it which started leaking tonight.
I turned on a tap in the bathroom to see what would happen and it stopped the leak - 4 hours later and still no leak from this nut/leaver.
It's got a me a bit worried though as I'm currently broke and without any knowledge of plumbing.
I think the plastic tube is going off into the washing machine, but I might be wrong, and the water is cold.
The only other thing which might be worth mentioning is that I hardly ever use the hot water at this property.
Thank you in advance. 🙂
Sounds like a washing machine isolation valve. The rubber washer may be on its last legs, Isolate replace washer and tighten back up.
Thanks for the help, Winston.
Question: In the meantime, to stop it leaking, what direction do I turn the small leaver (if that's even going to help it) as it's rather stiff and I don't want to aggravate things further?
If you turn lever across pipe/fitting it will be in off position
just try tightening the plastic nut that is leaking to see if loose
Get a tea towel and twist nut clockwise ,same way as if you were closing a tap,should stop leaking if hand tight,if not as Winston says,new washer
If in doubt call a local plumber I often do this stuff foc for oaps or £20 otherwise.
Reply to the thread, titled "Tiny red leaver leaking under sink" which is posted in UK Plumbers Forums on Plumbers Forums.
