Going to put in new iso valves and on the compression fitting should a smidgen of LSX be used around the olive?
On the other end will be fitting tap tail adaptors again using olive and smidgen of LSX.
www.toolstation.com
So is there any downside in using LSX?
Also would this be a better solution using iso valve plus tap tail adaptor to just using a flexi adaptor with built in iso?
Aim is long term leak prevention and repair if required.
Tap Tail Adaptors
These two tap tail adaptors give you the connections you need to fit your flexible tap tails with 15 mm isolation valves. The helical screw threads fix tightly onto the tap tail to make installation easy. The small size ensures you save space around the fitting and simplifies your set-up. The...
