springer101
Hi All
I'd be really grateful for any tips/tricks/advice on what may be a problem. I live in a 1920's mid terraced house (4 in the row off a main road). I've always had very poor low pressure water that up until now hasn't served much of a problem other than the half hour bath running regime which runs cold after about 10 mins (CW tank in loft and HWC in airing cupboard in bathroom itself with lots of banging and clunking reminicent of charlie and the chocolate factory)! Having decided to renovate the bathroom I would like a shower and have come to realize that this may pose a problem!
Where to start is my question, is this solvable and will I be able to have a longed for shower? I have tested the output of each of the taps as follows:
Kitchen Hot Tap: 3.50 Litres/min
Kitchen Cold Tap: 5.80 Litres/min
Bathrm Sink Hot: 3.09 Litres/min
Bathrm Sink Cold: 7.23 Litres/min
Bath Cold: 5.88 Litres/min
Bath Hot: Ridiculously variable - having run off hot - 5.55 Litres/min, 3.50 Litres/min, 7.74 Litres/min to almost a spit at some points!
I'm aware of the minimum standards and am about to phone the water company to come and investigate (as I've rightfully read from some previous posts on this great website!). I also think at this stage possibly (??) it may be worth my while replacing the boiler which is 20 years old whilst I'm ripping the bath out and may/may not install a seperate shower cubicle or over the bath (dont suppose it matters which). Am sure the pipes leading to everything are probably lead so will need replacing also. Any advice to offer would be most gratefully received on what I may/may not be able to do with this problem. I'm really not sure other than the above, where to go from here or what order to do everything in and would really like to know my options/necessities!
Many thanks for reading and pondering in advance! 😕
